MachinesTechnologies
Robot Technology in Production
An Interview with Jan Gotthold
by Oliver Hagenlocher 18. January 2024
18. January 2024
3.2K
The integration of robot technology into manufacturing processes is playing an increasingly important role in the modern industrial landscape. Jan Gotthold, Product Manager at EMAG Maschinenfabrik, provides an exciting insight into this area. Using EMAG’s drive shaft production line as an example, he demonstrates the key benefits of this technology.
The integration of robots into manufacturing processes is a hot topic in the industry. Mr. Gotthold, can you explain the main advantages using the EMAG manufacturing system for drive shafts as an example?
Jan Gotthold: Of course, robot-assisted production, as developed by EMAG for drive shafts, offers immense advantages. Firstly, we achieve economical production through optimal machine utilization, which saves costs. Secondly, the high autonomy of the system enables a reduction in worker involvement, which increases flexibility. Thirdly, we achieve high buffer volumes in a small area and fourthly, the capital investments are comparatively low.
VTC 100 interlinked with a robot cell with a G 160.
Production system for drive shafts interlinked using robot technology.
How does this system actually work and which machines are involved?
Jan Gotthold: At its core, the system consists of the VTC 100 vertical turning machine for 4-axis turning and the G 160 gear grinding machine for grinding. The VTC 100 is characterized by short paths and a powerful main spindle, which makes it ideal for high quantities.
VTC 100 shaft machining
The VTC 100 vertical turning machine is ideal for 4-axis turning of drive shafts. It is characterized by short travel distances and a powerful main spindle, which makes it ideal for high quantities.
The G 160, on the other hand, can boast extremely short chip-to-chip times of less than 2 seconds thanks to its axis concept, making it one of the fastest gear generating grinding machines on the market.
Gear grinding on the G 160
The G 160 gear generating grinding machine is one of the fastest gear grinding machines on the market. It is ideal for grinding drive shafts as it enables extremely short chip-to-chip times of less than 2 seconds.
The two machines are connected by a robot cell, which ensures fast and efficient processes.
Robot cell for handling the drive shafts
The robot cell is responsible for the fast and efficient handling of the drive shafts between the two machines. The direct link-up increases both process reliability and production efficiency.
How does this technology affect safety and efficiency in production?
Jan Gotthold: In addition to efficiency and user-friendliness, occupational safety is our top priority, which is why our machines and automation solutions meet the highest safety requirements.
Efficiency is increased by the reduced use of personnel and high availability alone. This means that less time is required for loading and unloading as well as for the machining processes, which leads to higher output.
 Please find here more information on our automation solutions.
GrindinginterviewManufacturing SystemsRobot automationVertical Turning Machine
How does… a CVT transmission actually work? Five questions – Five answers
Solution for E-Car Production: The HLC 150 H
Scroll free turning vs. Grinding vs. Hard Turning:...
VL 3 DUO: What makes this Dual-Spindle Lathe...
automation Automotive industry batch production car manufacturing chucked components CNC lathe CV Joints differentials Digitalization E-Mobility ECM ECM rifling EMAG EMAG LLC EMO 2019 External grinding gear gear cutting / gear hobbing Gear technology gearwheel Grinding Grinding technology hard machining Hard Turning Industry 4.0 interview laser welding lathe machine control machine tools Manufacturing Systems Manufacturing Technology mechanical engineering precision manufacturing process optimization production automation Retrofit Salach Service steering pinion Technology Forum transmission manufacturing Turning turning and grinding machine Vertical Turning Machine
