Machines
Rebuild for VL 3, VL 5, and VL 5i: How Machine Precision is restored in a predictable manner
Mechanical overhaul for VL 3, VL 5, and VL 5i with predictable downtime and a transparent cost structure.
by Oliver Hagenlocher 21. July 2026
21. July 2026
1.5K
A rebuild mechanically restores a proven VL machine to reliable production-ready condition. Instead of accepting declining precision, increasing downtime risks, or diminishing performance, the machine undergoes a targeted overhaul. For operators of the VL 3, VL 5, and VL 5i, this provides a predictable alternative to purchasing new equipment.
In batch production in particular, it’s not just machine availability that counts. What matters most is that the system produces with consistent precision, maintains stable cycle times, and avoids unplanned downtime. With a professional rebuild,  key mechanical assemblies are replaced or overhauled, restoring the machine to original precision  and continued to use productively.
When is a rebuild worthwhile for a VL machine?
A rebuild is worthwhile when a machine is fundamentally suited to the manufacturing process but can no longer achieve the desired performance mechanically. Typical signs include declining dimensional accuracy, increasing process corrections, wear-related malfunctions, or decreasing availability.
For the VL 3, VL 5, and VL 5i models, this often affects components subject to high mechanical stresses. These include linear units, feed drives, the main spindle, and the turret. These assemblies directly influence positioning accuracy, process stability, and repeatability in production.
A rebuild is particularly beneficial when the machine concept is still compatible with the range of parts being produced. Continuing to use the existing system keepscurrent processes stable, and no additional training costs.
Rebuild for VL 3, VL 5, and VL 5i: What Is Overhauled?
The VL rebuild focuses on key mechanical components that are critical for accuracy, dynamics, and process reliability. The scope of work is clearly defined and designed to minimize downtime.
Area  Measure  Benefits for Production
X- and Z-axes  Replacement of linear units  Restoration of axis accuracy
Feed system  Replacement of feed drives on the X and Z axes  Improved dynamics and more reliable positioning
Main Spindle  Installation of a new main spindle  Restoration of performance and reduced risk of downtime
Turret  Mechanical overhaul  Stable tool receptors and reliable tool change
Bearings and Seals  Replacement in the turret area  Fewer wear-related malfunctions and greater operational reliability
VL 3 and VL 5 machines in the context of a rebuild. Mechanical overhaul for greater precision and availability.
VL 3 and VL 5 rebuilds for planned machine overhauls. The rebuild extends the machine’s service life and reduces unplanned downtime in production.
How quickly is a VL machine ready for use again after a rebuild?
The VL rebuild is designed for a downtime of just 5 days. Within this timeframe, the machine undergoes a mechanical overhaul and returned to production.
For manufacturing facilities, this short downtime is a significant advantage. Machine downtime can be planned well in advance, production windows can be prepared, and the process remains manageable from an organizational standpoint. This reduces the risk of long, unplanned outages.
This is important for linked manufacturing systems. If a central machine breaks down unexpectedly, it can affect downstream processes. A planned rebuild helps limit such risks.
Why is the fixed price important for the rebuild?
The VL Rebuild is offered at a fixed price of €40,500.00 per machine*. This provides the operator with a clear budget for their decision.
A fixed price simplifies internal evaluation compared to alternatives such as individual repairs, general overhauls, or replacement investments. The costs are transparent from the outset. At the same time, the technical scope is defined, so the measure does not have to be planned as an open-ended repair with costs that are difficult to estimate.
This provides a clear framework for maintenance, production planning, and investment analysis: a defined price, a defined scope of work, and defined downtime.
How does a rebuild contribute to the machine’s service life?
Mechanical wear occurs over the years due to movement, loads, temperature changes, chips, cutting fluids, and process forces. Even robust machine tools gradually lose accuracy and availability as a result.
The rebuild focuses on components that are subject to heavy wear. New linear units, refurbished feed drives, a new main spindle, and a reconditioned turret restore key mechanical functions. This not only repairs the machine but also technically refreshes it in essential areas.
The goal is to extend the service life of the existing equipment. This can be economically attractive for companies if the machine base, basic structure, automation concept, and process integration continue to align with the component range.
Why is precision particularly important for VL machines?
VL machines are frequently used in high-productivity turning processes where dimensional accuracy, repeatability, and short non-cutting times are critical. If axes, the spindle, or the turret deteriorate due to wear, this directly affects production quality.
A worn linear unit can impair positioning accuracy. A stressed main spindle can negatively affect concentricity and cutting conditions. A worn turret can degrade tool positioning and process reliability.
A rebuild restores these mechanical fundamentals. As a result, the machine can once again operate with greater precision, stability, and predictability.
Rebuild as Part of a Predictive Maintenance Strategy
A rebuild should not be considered only after the machine has suffered an unplanned breakdown. The greatest benefit is achieved when the measure is planned in advance. This allows the operator to schedule the downtime within a suitable production window and prepare alternative production capacity.
Predictive maintenance not only addresses wear and tear but also mitigates production risks early on. A defined rebuild with a fixed scope and short implementation time fits perfectly into this strategy.
This transforms a potential malfunction into a predictable technical measure.
Find more current service promotions here at great rates
*Terms and Conditions:
  1. This offer is valid only for EMAG VL3, VL5, and VL5i machine models.
  2. The provision of services is contingent upon the system being freely accessible, the operator providing the necessary lifting equipment, and the operator ensuring a smooth process throughappropriate cooperation.
  3. Waiting times caused by the operator will be billed separately.
  4. This promotional offer is valid only within Europe, excluding Italy and France, during the promotional period through December 31, 2026.
  5. Services ordered as part of this promotional offer must be performed through April 30, 2027.
  6. This discount promotion cannot be combined with existing special customer discounts or service contracts.
  7. Any export expenses or applicable customs duties are excluded.
  8. The EMAG group’s General Terms and Conditions of Delivery apply.
EMAG Servicemachine overhaulmachine precisionmachine toolsmaintenanceRebuildRetrofitVL 3VL 5VL 5i
Vertical turning and grinding center for the precision machining of chucked components
Weapon Barrel Process Chain: From Raw-Parts to Finished Barrel
