TrackMotion: effective interlinking of production systems
by Markus Isgro 7. March 2018
7. March 2018
4.7K
A continued rise in the demand for customized systems and integrated solutions was predicted back in 2014 by a survey of German manufacturers of plant and machinery, in a study on the future perspectives for the industry in Germany. This is not surprising given the huge “Industry 4.0” trend, as extensive automation in the form of customer-specific system solutions is a fundamental prerequisite for the digitalization of production facilities. The machines used then form an integrated system that production planners can control from a central point. Moreover, many companies need to respond ever more quickly and flexibly to technological developments. Numerous different versions of parts and fluctuating unit volumes are typical for small and medium-sized production companies in the automotive industry.
“Building block” solutions
With the development of its “Modular Solutions” the EMAG Group was already responding to these developments by 2012. These “building block” solutions ensure highly effective and customized machining processes, from turning and grinding to gear hobbing. At the same time, the machines can be linked together easily thanks to their uniform transfer heights, software control, and internal automation systems. The “Modular Solutions,” which also include high-productivity VL turning machines for chucked parts, DUO machines (dual-spindle pick-up turning centers), and vertical hobbing machines, have since become the fastest-growing segment and growth engine in the EMAG Group.
TrackMotion automation keeps things moving
EMAG’s proprietary automation technology “TrackMotion” plays a crucial role in this: In this automation system, a so-called TransLift unit with a programmable electric gripper runs on a track more or less right through the machines. It picks up the raw part from a parts storage unit and transports it to one of the VT machines. It is then taken over by the pick-up automation system in the EMAG machine or by the workpiece gripper in the turret. Once the machining process is completed and the part is deposited by the pick-up spindle onto the outer drag frame, the TransLift unit conveys the part onward if required.
Complex production lines created with ease
Ultimately the combination of “modular” machines, various EMAG technologies, and the TrackMotion automation system opens up all kinds of possibilities. Even complex production lines for rotor shafts can be created, including soft machining, laser welding, hardening, hard machining, and grinding—and a simpler, more reliable, and more effective solution would be hard to imagine.
YouTube
Mit dem Laden des Videos akzeptieren Sie die Datenschutzerklärung von YouTube.
Mehr erfahren
Video laden
automationManufacturing Systems
Markus Isgro
Cylindrical grinder HG 208: the precision-fit shaft grinding solution
The first sod has been turned: EMAG expands its headquarters in Salach
