MachinesTechnologies
New Manufacturing System for Turbochargers
by Oliver Hagenlocher 16. August 2019
16. August 2019
5K
The production of turbocharger components is one of the most challenging tasks in automotive engineering and EMAG has created a complete line solution that delivers both speed and precision.
Turbochargers play a major role in the performance of engines in modern vehicles. By compressing fresh air that is drawn into the engine and pushing it out into the combustion chambers, turbochargers increase the performance of engines, or allow us to use smaller engines to achieve the same standards (downsizing). Rotating at a speed of approximately 290,000 rpm, the shaft in the turbocharger is under extreme stress and is subjected to very high temperatures. To make this possible, developers create these shafts with high performance materials that can withstand the stress from temperatures up to 1000°C. How can we efficiently and reliably perform the demanding finishing work on a welded turbine shaft and turbine?
Speedy New Line Solution!
EMAG has developed the perfect line solution to create these components, and all machines will come from a single source. The component will pass through five main processes – from initial turning and induction hardening, to grinding the shaft, wheel and shoulders. The final process is electro-chemical balancing on an EMAG ECM machine.
Networking @ EMO: Interview with Björn Svatek
Networking @ EMO 2019: Interview with Richard Keller of EMAG ECM
automation Automotive industry car manufacturing CNC lathe CV Joints differentials Digitalization E-Mobility ECM EMAG EMAG LLC EMO 2019 Energy efficiency gear gear cutting / gear hobbing Gear hobbing Gear technology gearwheel Grinding Grinding technology Hard Turning Industry 4.0 interview laser welding lathe machine control machine tools Manufacturing Systems Manufacturing Technology mechanical engineering Planetary gearbox power skiving precision machining precision manufacturing process optimization production automation Retrofit Salach Service steering pinion Technology Forum transmission manufacturing Turning turning and grinding machine Vertical Turning Machine
