MachinesTechnologies
VL 1 TWIN Dual-Spindle Turning Center with Loading Robot
by Markus Isgro 15. November 2019
15. November 2019
https://www.youtube.com/watch?v=hQh4gKpu_w0
9.5K
The VL 1 TWIN has set the new standard for the high-output, simultaneous machining of workpieces with a maximum dimaeter of 75 mm (3 in). This turning center has two main spindles in one machining area that are able to simultaneously machine two identical workpieces – resulting in substantially increased output quantities, and lower unit costs.
A Proven Structure
At EMAG, we stick to our proven principles – and the VL 1 TWIN is no exception. Including a rock-solid base made of MINERALIT® polymer concrete, an EMAG turret with direct drive, as well as two water-cooled motor spindles (independent alignment in the X and Z directions).
Complex Manufacturing Lines
The turning center is the ideal choice for configuring complex manufacturing lines based on modular solutions. The video shows two VL 1 TWIN machines coupled with a loading robot. The VL 1 TWIN is best suited for the mass production of transmission components such as planetary and sun gears, as well as bevel gears.
You will find all the relevant details about the VL 1 TWIN here.
transmission manufacturingVertical Turning Machine
Markus Isgro
“Our hobbing processes are now five times faster than before”
How stable is the current growth in the construction and utility vehicle industries?
