MachinesSuccess Story
EMAG at AMB: Vertical Turning Machine VT 2
by Markus Isgro 1. December 2016
1. December 2016
8K
Maximum Efficiency in Shaft Production. Short cycle times, high precision and safe processing are among the outstanding attributes of shaft machining on the turning machines of the VT series. These lathes literally turn the classical horizontal machining process on its head.
Four axes, short travels, a powerful main spindle – these are the strengths of the VT 2 turning machine. The use of a “two-sided” process massively reduces machining times on VT lathes, allowing for large component batch sizes to be manufactured quickly.
More here…
shaft componentsTurningVertical Turning Machine
Markus Isgro
New EMAG Press Release: Complete laser welding solutions for transmission manufacturing
Retrofit instead of new procurement: How EWS Weigele...
