{"name":"EMAG \u2013 Unser Unternehmensblog","description":"Erfahre alles rund um die EMAG Gruppe","url":"https:\/\/www.emag.com\/blog","home":"https:\/\/www.emag.com\/blog","gmt_offset":2,"timezone_string":"Europe\/Berlin","page_for_posts":0,"page_on_front":0,"show_on_front":"posts","namespaces":["oembed\/1.0","contact-form-7\/v1","yoast\/v1","backwpup\/v1","backwpup\/v2","livevisitor\/v1","penci\/v1","mcp","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/www.emag.com\/blog\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Die URL der Ressource, f\u00fcr die oEmbed-Daten abgerufen werden sollen.","type":"string","format":"uri","required":true},"format":{"description":"Das zu verwendende oEmbed-Format.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"Die maximale Breite des eingebundenen Frames in Pixel.","type":"integer","default":600,"required":false},"maxheight":{"description":"Die maximale H\u00f6he des eingebundenen Frames in Pixel.","type":"integer","required":false},"discover":{"description":"Ob eine oEmbed-Discovery-Anfrage f\u00fcr nicht autorisierte Anbieter durchgef\u00fchrt werden soll.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/oembed\/1.0\/proxy"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal"}]}},"\/yoast\/v1\/ai_content_planner\/get_outline":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"type":"string","description":"The post type to get a content outline for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true},"title":{"type":"string","description":"The title of the chosen content suggestion.","required":true},"intent":{"type":"string","description":"The intent of the chosen content suggestion.","required":true},"explanation":{"type":"string","description":"The explanation of the chosen content suggestion.","required":true},"keyphrase":{"type":"string","description":"The keyphrase of the chosen content suggestion.","required":true},"meta_description":{"type":"string","description":"The meta description of the chosen content suggestion.","required":true},"category":{"type":"object","properties":{"name":{"type":"string","required":true},"id":{"type":"integer","required":true}},"description":"The category of the chosen content suggestion. Use name \"\" and id -1 to indicate no category.","required":true},"recent_content":{"type":"array","maxItems":100,"items":{"type":"object","properties":{"title":{"type":"string","required":true,"maxLength":500},"description":{"type":"string","required":true,"maxLength":1000}},"additionalProperties":false},"description":"The recent content returned by the get_suggestions response.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_content_planner\/get_outline"}]}},"\/yoast\/v1\/ai_content_planner\/get_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"type":"string","description":"The post type to get content suggestions for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_content_planner\/get_suggestions"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/bulk_editor\/posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"content_type":{"type":"string","description":"The content type to fetch posts for.","required":true},"per_page":{"type":"integer","default":20,"minimum":1,"maximum":100,"description":"The number of posts to fetch.","required":false},"page":{"type":"integer","default":1,"minimum":1,"description":"The page of posts to fetch.","required":false},"search":{"type":"string","default":"","description":"The term to search posts by.","required":false},"status":{"type":"array","default":["publish","draft","pending","future"],"items":{"type":"string","enum":["publish","draft","pending","future"]},"description":"The post statuses to include.","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/bulk_editor\/posts"}]}},"\/yoast\/v1\/bulk_editor\/update_search":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/bulk_editor\/update_search"}]}},"\/yoast\/v1\/bulk_editor\/update_social":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/bulk_editor\/update_social"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/backwpup\/v1":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"backwpup\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1"}]}},"\/backwpup\/v1\/storagelistcompact":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/storagelistcompact"}]}},"\/backwpup\/v1\/cloud_is_authenticated":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/cloud_is_authenticated"}]}},"\/backwpup\/v1\/authenticate_cloud":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/authenticate_cloud"}]}},"\/backwpup\/v1\/delete_auth_cloud":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/delete_auth_cloud"}]}},"\/backwpup\/v1\/cloudsaveandtest":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/cloudsaveandtest"}]}},"\/backwpup\/v2":{"namespace":"backwpup\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"backwpup\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v2"}]}},"\/backwpup\/v2\/storages":{"namespace":"backwpup\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v2\/storages"}]}},"\/backwpup\/v2\/messages":{"namespace":"backwpup\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v2\/messages"}]}},"\/backwpup\/v1\/chatbot-context":{"namespace":"backwpup\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["GET"],"args":{"context_id":{"required":true},"context_token":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/chatbot-context"}]}},"\/backwpup\/v1\/updatejob":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":true},"activ":{"required":false},"storage_destinations":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/updatejob"}]}},"\/backwpup\/v1\/update-job-title":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":true},"title":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/update-job-title"}]}},"\/backwpup\/v1\/addjob":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/addjob"}]}},"\/backwpup\/v1\/delete_job":{"namespace":"backwpup\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"job_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/delete_job"}]}},"\/backwpup\/v1\/save_job_settings":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/save_job_settings"}]}},"\/backwpup\/v2\/save_job_format":{"namespace":"backwpup\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v2\/save_job_format"}]}},"\/backwpup\/v1\/save_files_exclusions":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":true},"backuproot":{"required":false},"backupplugins":{"required":false},"backupthemes":{"required":false},"backupuploads":{"required":false},"backupcontent":{"required":false},"fileexclude":{"required":false},"add":{"required":false},"backuppluginsexcludedirs":{"required":false},"backupthemesexcludedirs":{"required":false},"backupcontentexcludedirs":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/save_files_exclusions"}]}},"\/backwpup\/v1\/save_excluded_tables":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":true},"tabledb":{"required":false},"dbdumpfile":{"required":false},"dbdumpwpdbsettings":{"required":false},"dbdumpfilecompression":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/save_excluded_tables"}]}},"\/backwpup\/v1\/save_site_option":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/save_site_option"}]}},"\/backwpup\/v2\/backups\/(?P<id>\\d+)\/type":{"namespace":"backwpup\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true},"type":{"required":true}}}]},"\/backwpup\/v1\/getjobslist":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/getjobslist"}]}},"\/backwpup\/v1\/job-abort-status":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/job-abort-status"}]}},"\/backwpup\/v1\/startbackup":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":false},"first_backup":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/startbackup"}]}},"\/backwpup\/v1\/process_bulk_actions":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"required":true},"backups":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/process_bulk_actions"}]}},"\/backwpup\/v1\/backups":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"page":{"default":1,"required":false},"length":{"default":10,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/backups"}]}},"\/backwpup\/v1\/pagination":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"page":{"default":1,"required":false},"max_pages":{"default":10,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/pagination"}]}},"\/backwpup\/v1\/getblock":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/backwpup\/v1\/getblock"}]}},"\/livevisitor\/v1":{"namespace":"livevisitor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"livevisitor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/livevisitor\/v1"}]}},"\/livevisitor\/v1\/update\/(?P<post_id>\\d+)":{"namespace":"livevisitor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/livevisitor\/v1\/count\/(?P<post_id>\\d+)":{"namespace":"livevisitor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/penci\/v1":{"namespace":"penci\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"penci\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/penci\/v1"}]}},"\/penci\/v1\/penci_html_mega_menu":{"namespace":"penci\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/penci\/v1\/penci_html_mega_menu"}]}},"\/penci\/v1\/penci_archive_more_post":{"namespace":"penci\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/penci\/v1\/penci_archive_more_post"}]}},"\/penci\/v1\/penci_ajax_search":{"namespace":"penci\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":{"query":{"required":true},"number":{"default":5,"required":false},"nonce":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/penci\/v1\/penci_ajax_search"}]}},"\/penci\/v1\/reactions\/(?P<id>\\d+)":{"namespace":"penci\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false}}}]},"\/penci\/v1\/get_menu_data":{"namespace":"penci\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/penci\/v1\/get_menu_data"}]}},"\/mcp":{"namespace":"mcp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"mcp","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/mcp"}]}},"\/mcp\/mcp-adapter-default-server":{"namespace":"mcp","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST","GET","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/mcp\/mcp-adapter-default-server"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie categories zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie tags zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Den Ergebnissatz auf Elemente begrenzen, die oben gehalten werden.","type":"boolean","required":false},"ignore_sticky":{"description":"Ob oben gehaltene Beitr\u00e4ge ignoriert werden sollen oder nicht.","type":"boolean","default":true,"required":false},"format":{"description":"Den Ergebnissatz auf Elemente begrenzen, denen ein oder mehrere bestimmte Formate zugeordnet sind.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Das Format f\u00fcr den Beitrag.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Ob der Beitrag als oben gehalten behandelt werden soll oder nicht.","type":"boolean","required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"categories":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie post_tag zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"Die Reihenfolge des Beitrags in Bezug auf andere Beitr\u00e4ge.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Den Ergebnissatz auf alle Elemente bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Den Ergebnissatz auf alle Elemente begrenzen, au\u00dfer denen mit einer bestimmten \u00fcbergeordneten ID.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten Medientyps oder bestimmter Medientypen begrenzen.","type":"array","items":{"type":"string","enum":["image","video","audio","application","text"]},"required":false},"mime_type":{"default":null,"description":"Den Ergebnissatz auf Anh\u00e4nge eines bestimmten MIME-Typs oder bestimmter MIME-Typen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Anhang.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL zur bearbeiteten Bilddatei.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array an Bildbearbeitungen.","type":"array","minItems":1,"items":{"description":"Bildbearbeitung.","type":"object","required":["type","args"],"oneOf":[{"title":"Spiegeln","properties":{"type":{"description":"Die Art der Spiegelung.","type":"string","enum":["flip"]},"args":{"description":"Die Spiegelungs-Argumente.","type":"object","required":["flip"],"properties":{"flip":{"description":"Die Richtung der Spiegelung.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Ob in horizontaler Richtung gespiegelt werden soll.","type":"boolean"},"vertical":{"description":"Ob in vertikaler Richtung gespiegelt werden soll.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Rotations-Typ.","type":"string","enum":["rotate"]},"args":{"description":"Rotations-Argumente.","type":"object","required":["angle"],"properties":{"angle":{"description":"Winkel in Grad f\u00fcr die Rotation im Uhrzeigersinn.","type":"number"}}}}},{"title":"Zuschneiden","properties":{"type":{"description":"Typ des Zuschnitts.","type":"string","enum":["crop"]},"args":{"description":"Zuschnitt-Argumente.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Horizontale Position von links, an der der Zuschnitt beginnen soll, in Prozent der Bildbreite.","type":"number"},"top":{"description":"Vertikale Position von oben, an der der Zuschnitt beginnen soll, in Prozent der Bildh\u00f6he.","type":"number"},"width":{"description":"Die Breite des Zuschnitts in Prozent der Bildbreite.","type":"number"},"height":{"description":"Die H\u00f6he des Zuschnitts in Prozent der Bildh\u00f6he.","type":"number"}}}}}]},"required":false},"rotation":{"description":"Der Bereich in Grad, um den das Bild im Uhrzeigersinn gedreht werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Die x-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Die y-Position des Bildes in Prozent, an der das Zuschneiden des Bildes beginnen soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Die Breite des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Die H\u00f6he des Bildes in Prozent, auf die das Bild zugeschnitten werden soll. VERALTET: Stattdessen `modifiers` benutzen.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Die Beschriftung des Anhangs.","type":"object","properties":{"raw":{"description":"Die Beschriftung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"Die f\u00fcr die Anzeige umgewandelte HTML-Beschriftung des Anhangs.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Die Beschreibung des Anhangs.","type":"object","properties":{"raw":{"description":"Beschreibung f\u00fcr den Anhang, wie sie in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Beschreibung f\u00fcr den Anhang, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"Die ID des Beitrags, dem der Anhang zugeordnet ist.","type":"integer","required":false},"alt_text":{"description":"Alternativtext, der angezeigt wird, wenn der Anhang nicht angezeigt wird.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie menus zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die einen bestimmten menu_order-Wert haben.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"default":1,"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"default":0,"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID des \u00fcbergeordneten Objekts.","type":"integer","minimum":0,"required":false},"title":{"description":"Der Titel f\u00fcr das Objekt.","type":["string","object"],"properties":{"raw":{"description":"Titel f\u00fcr das Objekt, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr das Objekt, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"Die urspr\u00fcnglich repr\u00e4sentierte Objektfamilie, z.\u00a0B. \u201epost_type\u201c oder \u201etaxonomy\u201c.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Ein benannter Status f\u00fcr das Objekt.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Text f\u00fcr das Titelattribut des Linkelements dieses Men\u00fceintrags.","type":"string","required":false},"classes":{"description":"Klassennamen f\u00fcr das Linkelement dieses Men\u00fceintrags.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"Die Beschreibung dieses Men\u00fceintrags.","type":"string","required":false},"menu_order":{"description":"Die DB-ID des nav_menu_item, das gegebenenfalls der \u00fcbergeordnete Men\u00fceintrag dieses Elements ist; andernfalls 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Der urspr\u00fcnglich repr\u00e4sentierte Objekttyp, z.\u00a0B. \u201ecategory\u201c, \u201epost\u201c oder \u201eattachment\u201c.","type":"string","required":false},"object_id":{"description":"Die Datenbank-ID des urspr\u00fcnglichen Objekts, das dieser Men\u00fceintrag repr\u00e4sentiert, zum Beispiel die ID f\u00fcr Beitr\u00e4ge oder die term_id f\u00fcr Kategorien.","type":"integer","minimum":0,"required":false},"target":{"description":"Das Zielattribut des Linkelements f\u00fcr diesen Men\u00fceintrag.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"Die URL, auf die dieser Men\u00fceintrag zeigt.","type":"string","format":"uri","required":false},"xfn":{"description":"Die XFN-Beziehung, die durch den Link dieses Men\u00fceintrags beschrieben wird.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Die Begriffe, die dem Objekt in der Taxonomie nav_menu zugewiesen sind.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie wp_pattern_category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"wp_pattern_category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie wp_pattern_category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr die das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID eines Templates","type":"string","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Auf die angegebene Beitrags-ID begrenzen.","type":"integer","required":false},"area":{"description":"Auf den angegebenen Bereich des Template-Teils begrenzen.","type":"string","required":false},"post_type":{"description":"Inhaltstyp f\u00fcr die Templates.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"default":"","description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Beschreibung des Templates.","type":"string","required":false},"status":{"default":"publish","description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Die Titelform des Templates, f\u00fcr die das Fallback abgerufen werden soll","type":"string","required":true},"is_custom":{"description":"Gibt an, ob ein Template individuell oder Teil der Template-Hierarchie ist","type":"boolean","required":false},"template_prefix":{"description":"Das Template-Pr\u00e4fix f\u00fcr das erstellte Template. Dies wird verwendet, um den Haupt-Template-Typ zu extrahieren, z.\u00a0B. in `taxonomy-books` wird die `taxonomy` extrahiert","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"slug":{"description":"Eindeutige Titelform, die das Template identifiziert.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Theme-Kennung f\u00fcr das Template.","type":"string","required":false},"type":{"description":"Typ des Templates.","type":"string","required":false},"content":{"description":"Inhalt des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Inhalt f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit"]},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Template verwendet wird.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titel des Templates.","type":["object","string"],"properties":{"raw":{"description":"Der Titel f\u00fcr das Template, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Der HTML-Titel f\u00fcr das Template, der f\u00fcr die Anzeige transformiert wurde.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Beschreibung des Templates.","type":"string","required":false},"status":{"description":"Status des Templates.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Templates.","type":"integer","required":false},"area":{"description":"Wo das Template-Teil verwendet werden soll (Header, Footer etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Die ID eines Templates","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision der globalen Stile.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung der Revision f\u00fcr globale Stile.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"Die Theme-Kennung","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"Die ID der globalen Stile-Konfiguration.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Globale Stile.","type":["object"],"required":false},"settings":{"description":"Globale Einstellungen.","type":["object"],"required":false},"title":{"description":"Der Titel der globalen Stilvariante.","type":["object","string"],"properties":{"raw":{"description":"Der Titel der globalen Stilvariante, wie er in der Datenbank vorliegt.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Die Sammlung nach Objektattribut sortieren.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete Revision.","type":"integer","required":false},"id":{"description":"Eindeutige Kennung f\u00fcr die Revision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Revisionen k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit","embed"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Schriftfamilien-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"theme_json_version":{"description":"Die Version des theme.json-Schemas, das f\u00fcr Typografie-Einstellungen verwendet wird.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Schriftschnitt-Deklaration im theme.json-Format, als Zeichenfolge kodiert.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"Die ID der \u00fcbergeordneten Schriftfamilie des Schriftschnitts.","type":"integer","required":true},"id":{"description":"Eindeutige Kennung f\u00fcr den Schriftschnitt.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/portfolio":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Beitr\u00e4ge ausschlie\u00dft, die bestimmten Autoren zugewiesen sind.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Abfrage-Ergebnis auf Basis der Beziehung zwischen mehreren Taxonomien einschr\u00e4nken.","type":"string","enum":["AND","OR"],"required":false},"portfolio-category":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, denen bestimmte Begriffe in der Taxonomie portfolio-category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false},"operator":{"description":"Ob Elemente allen oder beliebigen festgelegten Begriffen zugewiesen sein m\u00fcssen.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"portfolio-category_exclude":{"description":"Ergebnissatz auf Elemente beschr\u00e4nken, au\u00dfer auf solche, denen bestimmte Begriffe in der Taxonomie portfolio-category zugewiesen sind.","type":["object","array"],"oneOf":[{"title":"Begriffs-ID-Liste","description":"Begriffe mit den gelisteten IDs vergleichen.","type":"array","items":{"type":"integer"}},{"title":"Taxonomie-Abfrage nach Begriffs-ID","description":"F\u00fchre eine erweiterte Begriffsabfrage durch.","type":"object","properties":{"terms":{"description":"Begriff-IDs.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Ob untergeordnete Begriffe in Begriffe, welche die Ergebnismenge begrenzen, mit einbezogen werden sollen.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"portfolio-category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie portfolio-category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/portfolio"}]}},"\/wp\/v2\/portfolio\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Setzt die Standardl\u00e4nge des Textauszugs au\u00dfer Kraft.","type":"integer","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"portfolio-category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie portfolio-category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/portfolio\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"Die ID f\u00fcr den Autor des Beitrags.","type":"integer","required":false},"excerpt":{"description":"Der Textauszug f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Textauszug f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Textauszug f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Ob der Textauszug durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"Die ID des hervorgehobenen Mediums f\u00fcr den Beitrag.","type":"integer","required":false},"comment_status":{"description":"Ob Kommentare f\u00fcr den Beitrag ge\u00f6ffnet sind oder nicht.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Ob der Beitrag gepingt werden kann oder nicht.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false},"portfolio-category":{"description":"Die Begriffe, die dem Beitrag in der Taxonomie portfolio-category zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/portfolio\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/penci-block":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Antwort auf Beitr\u00e4ge einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ge\u00e4ndert wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Wie die Sucheingabe interpretiert wird.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Ergebnissatz auf Beitr\u00e4ge mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Ergebnissatz auf Beitr\u00e4ge begrenzen, denen ein oder mehrere Status zugewiesen sind.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/penci-block"}]}},"\/wp\/v2\/penci-block\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Beitrag.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false}}}]},"\/wp\/v2\/penci-block\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"date":{"description":"Das Datum der Ver\u00f6ffentlichung des Beitrags, in der Zeitzone der Website.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Beitrag ver\u00f6ffentlicht wurde.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Beitrag, die f\u00fcr seinen Typ eindeutig ist.","type":"string","required":false},"status":{"description":"Ein benannter Status f\u00fcr den Beitrag.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Ein Passwort, um den Zugriff auf Inhalt und Textauszug zu sch\u00fctzen.","type":"string","required":false},"title":{"description":"Der Titel f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Titel f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Titel f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Der Inhalt f\u00fcr den Beitrag.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Beitrag, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Beitrag, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Die Version des Inhaltsblock-Formats, das von dem Beitrag verwendet wird.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Ob der Inhalt durch ein Passwort gesch\u00fctzt ist.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Die Theme-Datei, die zur Anzeige des Beitrags benutzt wird.","type":"string","required":false}}}]},"\/wp\/v2\/penci-block\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"Die ID f\u00fcr die \u00fcbergeordnete automatische Speicherung.","type":"integer","required":false},"id":{"description":"Die ID f\u00fcr die automatische Speicherung.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Eine alphanumerische Kennung f\u00fcr den Inhaltstyp.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Eine alphanumerische Kennung f\u00fcr den Status.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Ergebnisse auf Taxonomien begrenzen, die einem bestimmten Inhaltstyp zugeordnet sind.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Eine alphanumerische Kennung f\u00fcr die Taxonomie.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false},"locations":{"description":"Die dem Men\u00fc zugeordneten Positionen.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ob Seiten der obersten Ebene automatisch zu diesem Men\u00fc hinzugef\u00fcgt werden sollen.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/portfolio-category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Begriffsattribut sortieren.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Ob Begriffe ausgeblendet werden sollen, die keinen Beitr\u00e4gen zugewiesen sind.","type":"boolean","default":false,"required":false},"parent":{"description":"Den Ergebnissatz auf Begriffe begrenzen, die einem bestimmten \u00fcbergeordneten Objekt zugewiesen sind.","type":"integer","required":false},"post":{"description":"Ergebnissatz auf Begriffe begrenzen, die einem bestimmten Beitrag zugewiesen sind.","type":"integer","default":null,"required":false},"slug":{"description":"Ergebnissatz auf Begriffe mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":true},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/portfolio-category"}]}},"\/wp\/v2\/portfolio-category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"description":{"description":"HTML-Beschreibung des Begriffs.","type":"string","required":false},"name":{"description":"HTML-Titel f\u00fcr den Begriff.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Begriff, die eindeutig f\u00fcr ihren Typ ist.","type":"string","required":false},"parent":{"description":"Die ID des \u00fcbergeordneten Begriffs.","type":"integer","required":false},"meta":{"description":"Metafelder.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Begriff.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Begriffe k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"default":"asc","description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Sammlung nach Benutzerattribut sortieren.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Ergebnissatz auf Benutzer mit einer oder mehreren bestimmten Titelformen begrenzen.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Ergebnissatz auf Benutzer begrenzen, die mindestens einer bestimmten Rolle entsprechen. Akzeptiert eine CSV-Liste oder eine einzelne Rolle.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die mindestens eine bestimmte angegebene Berechtigung haben. Akzeptiert werden eine CSV-Liste oder eine einzelne Berechtigung.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Ergebnissatz auf Benutzer begrenzen, die als Autoren gelten.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Den Ergebnissatz auf Benutzer begrenzen, die Beitr\u00e4ge ver\u00f6ffentlicht haben.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","portfolio":"portfolio","penci-block":"penci-block"}},"required":false},"search_columns":{"default":[],"description":"Array mit den zu durchsuchenden Spaltennamen.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":true},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":true},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","en_GB","es_MX"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":true},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"penci_avatar":{"description":"The users simple local avatar","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","en_GB","es_MX"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"penci_avatar":{"description":"The users simple local avatar","type":"object","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Benutzer.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Anmeldename f\u00fcr den Benutzer.","type":"string","required":false},"name":{"description":"Der Anzeigename f\u00fcr den Benutzer.","type":"string","required":false},"first_name":{"description":"Vorname f\u00fcr den Benutzer.","type":"string","required":false},"last_name":{"description":"Nachname f\u00fcr den Benutzer.","type":"string","required":false},"email":{"description":"Die E-Mail-Adresse f\u00fcr den Benutzer.","type":"string","format":"email","required":false},"url":{"description":"Die URL des Benutzers.","type":"string","format":"uri","required":false},"description":{"description":"Die Beschreibung des Benutzers.","type":"string","required":false},"locale":{"description":"Sprachumgebung f\u00fcr den Benutzer.","type":"string","enum":["","en_US","de_DE","en_GB","es_MX"],"required":false},"nickname":{"description":"Der Spitzname f\u00fcr den Benutzer.","type":"string","required":false},"slug":{"description":"Eine alphanumerische Kennung f\u00fcr den Benutzer.","type":"string","required":false},"roles":{"description":"Rollen, die dem Benutzer zugewiesen sind.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Passwort f\u00fcr den Benutzer (nie enthalten).","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"Das Datum und die Uhrzeit der Aktualisierung der Einstellungen.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"penci_avatar":{"description":"The users simple local avatar","type":"object","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Setzen auf true erforderlich, denn Benutzer k\u00f6nnen nicht in den Papierkorb gelegt werden.","required":false},"reassign":{"type":"integer","description":"Die Beitr\u00e4ge und Links des gel\u00f6schten Benutzers dieser Benutzer-ID neu zuweisen.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Eine UUID, die von der Anwendung bereitgestellt wird, um sie eindeutig zu identifizieren. Es wird empfohlen, eine UUID\u00a0v5 mit dem URL- oder DNS-Namensraum zu verwenden.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Der Name des Anwendungspassworts.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"after":{"description":"Antwort auf Kommentare einschr\u00e4nken, die nach einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"author":{"description":"Ergebnissatz auf Kommentare begrenzen, denen bestimmte Benutzer-IDs zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Sicherstellen, dass der Ergebnissatz Kommentare ausschlie\u00dft, die einer bestimmten Benutzer-ID zugewiesen sind. Erfordert eine Autorisierung.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Den Ergebnissatz auf den einer speziellen E-Mail-Adresse eines Autors begrenzen. Erfordert eine Autorisierung.","format":"email","type":"string","required":false},"before":{"description":"Antwort auf Kommentare einschr\u00e4nken, die vor einem bestimmten ISO8601-konformen Datum ver\u00f6ffentlicht wurden.","type":"string","format":"date-time","required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Kommentarattribut sortieren.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Den Ergebnissatz auf Kommentare bestimmter \u00fcbergeordneter IDs begrenzen.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Sicherstellen, dass der Ergebnissatz bestimmte \u00fcbergeordnete IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Ergebnissatz auf Kommentare begrenzen, die bestimmten Beitrags-IDs zugewiesen sind.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Status zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"type":{"default":"comment","description":"Ergebnissatz auf Kommentare begrenzen, denen ein bestimmter Typ zugewiesen ist. Erfordert eine Autorisierung.","type":"string","required":false},"password":{"description":"Das Passwort f\u00fcr den Beitrag, falls dieser passwortgesch\u00fctzt ist.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"default":0,"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"author":{"description":"Die ID des Benutzerobjekts, falls der Autor ein Benutzer war.","type":"integer","required":false},"author_email":{"description":"E-Mail-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"email","required":false},"author_ip":{"description":"IP-Adresse f\u00fcr den Autor des Kommentars.","type":"string","format":"ip","required":false},"author_name":{"description":"Der Anzeigename f\u00fcr den Kommentarautor.","type":"string","required":false},"author_url":{"description":"URL f\u00fcr den Autor des Kommentars.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"User Agent f\u00fcr den Autor des Kommentars.","type":"string","required":false},"content":{"description":"Der Inhalt f\u00fcr den Kommentar.","type":"object","properties":{"raw":{"description":"Inhalt f\u00fcr den Kommentar, wie er in der Datenbank vorliegt.","type":"string","context":["edit"]},"rendered":{"description":"HTML-Inhalt f\u00fcr den Kommentar, transformiert f\u00fcr die Anzeige.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"Datum, an dem der Kommentar ver\u00f6ffentlicht wurde, in der Zeitzone der Website.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"Das Datum in UTC, an dem der Kommentar ver\u00f6ffentlicht wurde.","type":"string","format":"date-time","required":false},"parent":{"description":"Die ID f\u00fcr den \u00fcbergeordneten Kommentar.","type":"integer","required":false},"post":{"description":"Die ID des zugeordneten Beitragsobjekts.","type":"integer","required":false},"status":{"description":"Status des Kommentars.","type":"string","required":false},"meta":{"description":"Metafelder.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Status der Anmerkung","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Eindeutige Kennung f\u00fcr den Kommentar.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Ob der Papierkorb umgangen und die L\u00f6schung erzwungen werden soll.","required":false},"password":{"description":"Das Passwort f\u00fcr den \u00fcbergeordneten Beitrag des Kommentars (wenn der Beitrag passwortgesch\u00fctzt ist).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"type":{"default":"post","description":"Ergebnisse auf Elemente eines Objekt-Typs beschr\u00e4nken.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Ergebnisse auf einen oder mehrere Objekt-Subtypen einschr\u00e4nken.","type":"array","items":{"enum":["post","page","portfolio","penci-block","category","post_tag","portfolio-category","any"],"type":"string"},"required":false},"exclude":{"description":"Sicherstellen, dass der Ergebnissatz bestimmte IDs ausschlie\u00dft.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Ergebnissatz auf bestimmte IDs begrenzen.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Eindeutiger registrierter Name f\u00fcr den Block.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attribute f\u00fcr den Block.","type":"object","default":[],"required":false},"post_id":{"description":"Die ID des Beitragskontextes.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Blockname.","type":"string","required":false},"namespace":{"description":"Block-Namensraum.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"themeisle_sdk_promotions":{"title":"","description":"","type":"string","required":false},"themeisle_sdk_promotions_otter_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_optimole_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_rop_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_neve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_redirection_cf7_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_hyve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_wp_full_pay_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_masteriyo_installed":{"title":"","description":"","type":"boolean","required":false},"title":{"title":"Titel","description":"Website-Titel.","type":"string","required":false},"description":{"title":"Untertitel","description":"Website-Untertitel.","type":"string","required":false},"timezone":{"title":"","description":"Eine Stadt in deiner Zeitzone.","type":"string","required":false},"date_format":{"title":"","description":"Ein Datumsformat f\u00fcr alle datumsbasierten Zeichenfolgen.","type":"string","required":false},"time_format":{"title":"","description":"Ein Zeitformat f\u00fcr alle zeitbasierten Zeichenfolgen.","type":"string","required":false},"start_of_week":{"title":"","description":"Die Zahl eines Wochentages, mit dem die Woche beginnen sollte.","type":"integer","required":false},"language":{"title":"","description":"Der WordPress-Lokalisierungscode.","type":"string","required":false},"use_smilies":{"title":"","description":"Emoticons wie :-) und :-P als Grafiken anzeigen.","type":"boolean","required":false},"default_category":{"title":"","description":"Standard-Beitragskategorie.","type":"integer","required":false},"default_post_format":{"title":"","description":"Standard-Beitragsformat.","type":"string","required":false},"posts_per_page":{"title":"Maximale Beitragsanzahl pro Seite","description":"Maximal angezeigte Beitr\u00e4ge.","type":"integer","required":false},"show_on_front":{"title":"Vorne anzeigen","description":"Was auf der Homepage angezeigt werden soll","type":"string","required":false},"page_on_front":{"title":"Titelseite","description":"Die ID der Seite, die auf der Homepage angezeigt werden soll","type":"integer","required":false},"page_for_posts":{"title":"","description":"Die ID der Seite, auf der die neuesten Beitr\u00e4ge angezeigt werden sollen","type":"integer","required":false},"default_ping_status":{"title":"","description":"Link-Benachrichtigungen von anderen Blogs (Pingbacks und Trackbacks) zu neuen Beitr\u00e4gen erlauben.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Kommentare bei neuen Beitr\u00e4gen erlauben","description":"Erlaubt Personen, neue Beitr\u00e4ge zu kommentieren.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Website-Logo.","type":"integer","required":false},"site_icon":{"title":"Icon","description":"Website-Icon.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Ergebnissatz auf Themes begrenzen, die einem oder mehreren Status zugewiesen sind.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"Das Stylesheet des Themes. Dieses identifiziert das Theme eindeutig.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false},"status":{"description":"Beschr\u00e4nkt die Ergebnisse auf Plugins mit dem angegebenen Status.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Titelform im WordPress.org-Plugin-Verzeichnis.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Der Aktivierungsstatus des Plugins.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die ID einer registrierten Seitenleiste","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Verschachtelte Widgets.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false},"form_data":{"description":"Serialisierte Widget-Formulardaten zur Kodierung in Instanz-Einstellungen.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Die Widget-Typ-ID.","type":"string","required":true},"instance":{"description":"Aktuelle Instanz-Einstellungen des Widgets.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"Die Seitenleiste, f\u00fcr die Widgets zur\u00fcckgegeben werden sollen.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":true},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Eindeutige Kennung f\u00fcr das Widget.","type":"string","required":false},"id_base":{"description":"Typ des Widgets. Entspricht der ID im Endpunkt widget-types.","type":"string","required":false},"sidebar":{"description":"Die Seitenleiste, zu der das Widget geh\u00f6rt.","type":"string","required":false},"instance":{"description":"Instanz-Einstellungen des Widgets, falls unterst\u00fctzt.","type":"object","properties":{"encoded":{"description":"Base64-kodierte Darstellung der Instanz-Einstellungen.","type":"string","context":["edit"]},"hash":{"description":"Kryptographischer Hash der Instanz-Einstellungen.","type":"string","context":["edit"]},"raw":{"description":"Nicht kodierte Instanz-Einstellungen, falls unterst\u00fctzt.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"URL-kodierte Formulardaten aus dem Widget-Adminformular. Werden verwendet, um ein Widget zu aktualisieren, das keine Instanz unterst\u00fctzt. Nur Schreibzugriff.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Ob das Entfernen des Widgets erzwungen werden soll oder ob es in die inaktive Seitenleiste verschoben werden soll.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Ergebnissatz auf Bl\u00f6cke beschr\u00e4nken, die mit dem Suchbegriff \u00fcbereinstimmen.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","minLength":1,"required":false},"category":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Kategorie-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Stichwort-ID \u00fcbereinstimmen.","type":"integer","minimum":1,"required":false},"slug":{"description":"Ergebnisse auf die beschr\u00e4nken, die mit einer Vorlage (Titelform) \u00fcbereinstimmen.","type":"array","required":false},"offset":{"description":"Den Ergebnissatz um eine bestimmte Anzahl von Elementen verschieben.","type":"integer","required":false},"order":{"description":"Das Sortierattribut aufsteigend oder absteigend sortieren.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sammlung nach Beitragsattribut sortieren.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"Zu verarbeitende URL.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Eine alphanumerische Kennung f\u00fcr die Men\u00fcposition.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Eine eindeutige Kennung f\u00fcr die F\u00e4higkeitskategorie.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Eingabeparameter f\u00fcr die Ausf\u00fchrung der F\u00e4higkeit.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Die Ergebnisse auf F\u00e4higkeiten einer bestimmten F\u00e4higkeitskategorie begrenzen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Eindeutige Kennung f\u00fcr die F\u00e4higkeit.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Aktuelle Seite der Sammlung.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Maximale Anzahl der im Ergebnissatz zur\u00fcckzugebenden Elemente.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Ergebnisse auf alle begrenzen, die mit einer Zeichenfolge \u00fcbereinstimmen.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<name>[a-z][a-z0-9-]*\/[a-z][a-z0-9-]*)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Der Icon-Name.","type":"string","required":false},"context":{"description":"Geltungsbereich, unter dem die Anfrage erfolgt; bestimmt die in der Antwort vorhandenen Felder.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]}},"site_logo":0,"site_icon":0,"site_icon_url":"http:\/\/www.blog.emag.ubuntu.clickstorm.de\/blog\/wp-content\/uploads\/2016\/12\/EMAG_32x32-1.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}]}}
