{"name":"Grupo EMAG - Blog de la empresa","description":"Contribuciones a maquinaria, tecnolog\u00edas y m\u00e1s","url":"https:\/\/www.emag.com\/blog\/es","home":"https:\/\/www.emag.com\/blog\/es","gmt_offset":1,"timezone_string":"Europe\/Berlin","page_for_posts":0,"page_on_front":0,"show_on_front":"posts","namespaces":["oembed\/1.0","contact-form-7\/v1","yoast\/v1","backwpup\/v1","backwpup\/v2","livevisitor\/v1","penci\/v1","mcp","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/www.emag.com\/blog\/es\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL del recurso del que recuperar los datos oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL del recurso del que recuperar los datos oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"El formato oEmbed a utilizar.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"El ancho m\u00e1ximo del marco de incrustaci\u00f3n en p\u00edxeles.","type":"integer","default":600,"required":false},"maxheight":{"description":"La altura m\u00e1xima del marco de incrustaci\u00f3n en p\u00edxeles.","type":"integer","required":false},"discover":{"description":"Si se realizar\u00e1 una petici\u00f3n de descubrimiento de oEmbed para proveedores no sancionados.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/oembed\/1.0\/proxy"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_content_planner\/banner_permanent_dismissal"}]}},"\/yoast\/v1\/ai_content_planner\/get_outline":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"type":"string","description":"The post type to get a content outline for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true},"title":{"type":"string","description":"The title of the chosen content suggestion.","required":true},"intent":{"type":"string","description":"The intent of the chosen content suggestion.","required":true},"explanation":{"type":"string","description":"The explanation of the chosen content suggestion.","required":true},"keyphrase":{"type":"string","description":"The keyphrase of the chosen content suggestion.","required":true},"meta_description":{"type":"string","description":"The meta description of the chosen content suggestion.","required":true},"category":{"type":"object","properties":{"name":{"type":"string","required":true},"id":{"type":"integer","required":true}},"description":"The category of the chosen content suggestion. Use name \"\" and id -1 to indicate no category.","required":true},"recent_content":{"type":"array","maxItems":100,"items":{"type":"object","properties":{"title":{"type":"string","required":true,"maxLength":500},"description":{"type":"string","required":true,"maxLength":1000}},"additionalProperties":false},"description":"The recent content returned by the get_suggestions response.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_content_planner\/get_outline"}]}},"\/yoast\/v1\/ai_content_planner\/get_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"post_type":{"type":"string","description":"The post type to get content suggestions for.","required":true},"language":{"type":"string","description":"The language the content is written in.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_content_planner\/get_suggestions"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/bulk_editor\/posts_content":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"ids":{"type":"array","minItems":1,"maxItems":20,"items":{"type":"integer","minimum":1},"description":"The IDs of the posts to return the content of. Accepts a comma separated list.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/bulk_editor\/posts_content"}]}},"\/yoast\/v1\/bulk_editor\/posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"content_type":{"type":"string","description":"The content type to fetch posts for.","required":true},"per_page":{"type":"integer","default":20,"minimum":1,"maximum":100,"description":"The number of posts to fetch.","required":false},"page":{"type":"integer","default":1,"minimum":1,"description":"The page of posts to fetch.","required":false},"search":{"type":"string","default":"","description":"The term to search posts by.","required":false},"status":{"type":"array","default":["publish","draft","pending","future"],"items":{"type":"string","enum":["publish","draft","pending","future"]},"description":"The post statuses to include.","required":false},"needs_improvement":{"type":"array","default":[],"items":{"type":"string","enum":["seo_title","meta_description","social_title","social_description"]},"description":"The fields to filter posts by; a field matches when it is empty, or (for search fields, while SEO analysis is enabled and the content type shows Yoast's controls and assessments) when its score needs improvement.","required":false},"include":{"type":"array","default":[],"maxItems":100,"items":{"type":"integer","minimum":1},"description":"Limits the posts to these post IDs, e.g. a selection carried over from the posts overview.","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/bulk_editor\/posts"}]}},"\/yoast\/v1\/bulk_editor\/update_scores":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post score updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/bulk_editor\/update_scores"}]}},"\/yoast\/v1\/bulk_editor\/update_search":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/bulk_editor\/update_search"}]}},"\/yoast\/v1\/bulk_editor\/update_social":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"items":{"type":"array","description":"The per-post updates to apply.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/bulk_editor\/update_social"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/action_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/yoast\/v1\/action_tracking"}]}},"\/backwpup\/v1":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"backwpup\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1"}]}},"\/backwpup\/v1\/storagelistcompact":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/storagelistcompact"}]}},"\/backwpup\/v1\/cloud_is_authenticated":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/cloud_is_authenticated"}]}},"\/backwpup\/v1\/authenticate_cloud":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/authenticate_cloud"}]}},"\/backwpup\/v1\/delete_auth_cloud":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/delete_auth_cloud"}]}},"\/backwpup\/v1\/cloudsaveandtest":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/cloudsaveandtest"}]}},"\/backwpup\/v2":{"namespace":"backwpup\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"backwpup\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v2"}]}},"\/backwpup\/v2\/storages":{"namespace":"backwpup\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v2\/storages"}]}},"\/backwpup\/v2\/messages":{"namespace":"backwpup\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v2\/messages"}]}},"\/backwpup\/v1\/chatbot-context":{"namespace":"backwpup\/v1","methods":["POST","GET"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["GET"],"args":{"context_id":{"required":true},"context_token":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/chatbot-context"}]}},"\/backwpup\/v1\/updatejob":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":true},"activ":{"required":false},"storage_destinations":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/updatejob"}]}},"\/backwpup\/v1\/update-job-title":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":true},"title":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/update-job-title"}]}},"\/backwpup\/v1\/addjob":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/addjob"}]}},"\/backwpup\/v1\/delete_job":{"namespace":"backwpup\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":{"job_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/delete_job"}]}},"\/backwpup\/v1\/save_job_settings":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/save_job_settings"}]}},"\/backwpup\/v2\/save_job_format":{"namespace":"backwpup\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v2\/save_job_format"}]}},"\/backwpup\/v1\/save_files_exclusions":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":true},"backuproot":{"required":false},"backupplugins":{"required":false},"backupthemes":{"required":false},"backupuploads":{"required":false},"backupcontent":{"required":false},"fileexclude":{"required":false},"add":{"required":false},"backuppluginsexcludedirs":{"required":false},"backupthemesexcludedirs":{"required":false},"backupcontentexcludedirs":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/save_files_exclusions"}]}},"\/backwpup\/v1\/save_excluded_tables":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":true},"tabledb":{"required":false},"dbdumpfile":{"required":false},"dbdumpwpdbsettings":{"required":false},"dbdumpfilecompression":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/save_excluded_tables"}]}},"\/backwpup\/v1\/save_site_option":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/save_site_option"}]}},"\/backwpup\/v2\/backups\/(?P<id>\\d+)\/type":{"namespace":"backwpup\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"required":true},"type":{"required":true}}}]},"\/backwpup\/v1\/getjobslist":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/getjobslist"}]}},"\/backwpup\/v1\/job-abort-status":{"namespace":"backwpup\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"job_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/job-abort-status"}]}},"\/backwpup\/v1\/startbackup":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"job_id":{"required":false},"first_backup":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/startbackup"}]}},"\/backwpup\/v1\/process_bulk_actions":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"action":{"required":true},"backups":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/process_bulk_actions"}]}},"\/backwpup\/v1\/backups":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"page":{"default":1,"required":false},"length":{"default":10,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/backups"}]}},"\/backwpup\/v1\/pagination":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"page":{"default":1,"required":false},"max_pages":{"default":10,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/pagination"}]}},"\/backwpup\/v1\/getblock":{"namespace":"backwpup\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/backwpup\/v1\/getblock"}]}},"\/livevisitor\/v1":{"namespace":"livevisitor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"livevisitor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/livevisitor\/v1"}]}},"\/livevisitor\/v1\/update\/(?P<post_id>\\d+)":{"namespace":"livevisitor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/livevisitor\/v1\/count\/(?P<post_id>\\d+)":{"namespace":"livevisitor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/penci\/v1":{"namespace":"penci\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"penci\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/penci\/v1"}]}},"\/penci\/v1\/penci_html_mega_menu":{"namespace":"penci\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/penci\/v1\/penci_html_mega_menu"}]}},"\/penci\/v1\/penci_archive_more_post":{"namespace":"penci\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/penci\/v1\/penci_archive_more_post"}]}},"\/penci\/v1\/penci_ajax_search":{"namespace":"penci\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":{"query":{"required":true},"number":{"default":5,"required":false},"nonce":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/penci\/v1\/penci_ajax_search"}]}},"\/penci\/v1\/reactions\/(?P<id>\\d+)":{"namespace":"penci\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"required":false}}}]},"\/penci\/v1\/get_menu_data":{"namespace":"penci\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/penci\/v1\/get_menu_data"}]}},"\/mcp":{"namespace":"mcp","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"mcp","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/mcp"}]}},"\/mcp\/mcp-adapter-default-server":{"namespace":"mcp","methods":["POST","GET","DELETE"],"endpoints":[{"methods":["POST","GET","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/mcp\/mcp-adapter-default-server"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las entradas asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Aseg\u00fara que el conjunto de resultados excluye las entradas asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limita la respuesta a entradas publicadas antes de  una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limitar el conjunto de resultados a los elementos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si incluir los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limitar el conjunto de resultados a los elementos excepto a aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si incluir los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limitar el conjunto de resultados a los elementos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limitar el conjunto de resultados a los elementos excepto a aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limitar el conjunto de resultados a elementos que sean fijos.","type":"boolean","required":false},"ignore_sticky":{"description":"Ignorar (o no) las entradas fijas.","type":"boolean","default":true,"required":false},"format":{"description":"Limita el conjunto de resultados a los elementos asignados a uno o varios formatos dados.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud predeterminado del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_yoast_wpseo_focuskw":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_title":{"type":"string","title":"","description":"","default":""},"_yoast_wpseo_metadesc":{"type":"string","title":"","description":"","default":""},"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las entradas asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Aseg\u00fara que el conjunto de resultados excluye las entradas asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limita la respuesta a entradas publicadas antes de  una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limita los resultados a entradas con un valor espec\u00edfico menu_order.","type":"integer","required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar los resultados a todos los elementos excepto aquellos con un identificador padre espec\u00edfico.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior del objeto.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud predeterminado del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior del objeto.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID del superior del objeto.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"editor_notices":{"type":"array","title":"","description":"","default":[],"items":{"type":"string"}},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las entradas asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Aseg\u00fara que el conjunto de resultados excluye las entradas asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limita la respuesta a entradas publicadas antes de  una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar los resultados a todos los elementos excepto aquellos con un identificador padre espec\u00edfico.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limitar el conjunto de resultados a adjuntos de un tipo o tipos de medio en particular.","type":"array","items":{"type":"string","enum":["image","video","audio","application","text"]},"required":false},"mime_type":{"default":null,"description":"Limitar el conjunto de resultados a adjuntos de un tipo o tipos MIME en particular.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, si existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"Si se generan subtama\u00f1os de imagen.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Si se convierten formatos de imagen.","required":false},"url":{"type":"string","format":"uri","description":"URL de una imagen externa para cargar lateralmente en la biblioteca de medios, en lugar de subir un archivo.","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, si existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para el adjunto.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL al archivo de la imagen editada.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array de las ediciones de la imagen.","type":"array","minItems":1,"items":{"description":"Edici\u00f3n de la imagen.","type":"object","required":["type","args"],"oneOf":[{"title":"Voltear","properties":{"type":{"description":"Tipo de volteo.","type":"string","enum":["flip"]},"args":{"description":"Argumentos del volteo.","type":"object","required":["flip"],"properties":{"flip":{"description":"Direcci\u00f3n de volteo.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Si se debe voltear en direcci\u00f3n horizontal.","type":"boolean"},"vertical":{"description":"Si se debe voltear en direcci\u00f3n vertical.","type":"boolean"}}}}}}},{"title":"Rotaci\u00f3n","properties":{"type":{"description":"Tipo de rotaci\u00f3n.","type":"string","enum":["rotate"]},"args":{"description":"Argumentos de rotaci\u00f3n.","type":"object","required":["angle"],"properties":{"angle":{"description":"\u00c1ngulo a girar en el sentido de las agujas del reloj en grados.","type":"number"}}}}},{"title":"Recortar","properties":{"type":{"description":"Tipo de recorte.","type":"string","enum":["crop"]},"args":{"description":"Argumentos del recorte.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Posici\u00f3n horizontal desde la izquierda para comenzar el recorte como un porcentaje del ancho de la imagen.","type":"number"},"top":{"description":"Posici\u00f3n vertical desde la parte superior para comenzar el recorte como un porcentaje de la altura de la imagen.","type":"number"},"width":{"description":"Ancho del recorte como un porcentaje del ancho de la imagen.","type":"number"},"height":{"description":"Altura del recorte como un porcentaje de la altura de la imagen.","type":"number"}}}}}]},"required":false},"rotation":{"description":"La cantidad a girar la imagen en el sentido de las agujas del reloj en grados. OBSOLETO: usa `modifiers` en su lugar.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Como un porcentaje de la imagen, la posici\u00f3n en el eje de las x en la que comienza el recorte. OBSOLETO: usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Como un porcentaje de la imagen, la posici\u00f3n en el eje de las y en la que comienza el recorte. OBSOLETO: usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Como un porcentaje de la imagen, el ancho a la que recortar la imagen. OBSOLETO: usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Como un porcentaje de la imagen, la altura a la que recortar la imagen. OBSOLETO: usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, si existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para el adjunto.","type":"integer","required":false},"image_size":{"description":"Tama\u00f1o de imagen. Puede ser un nombre de un solo tama\u00f1o o un array de nombres de tama\u00f1o para registrar el mismo archivo en varios tama\u00f1os.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"Si se convierten formatos de imagen.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para el adjunto.","type":"integer","required":false},"sub_sizes":{"description":"Array de metadatos de subtama\u00f1os recopilados de las respuestas de carga lateral.","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"Nombre del tama\u00f1o o un array de nombres de tama\u00f1o cuando un solo archivo se registra en varios tama\u00f1os con dimensiones coincidentes.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a entradas publicadas antes de  una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de objeto.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limitar el conjunto de resultados a los elementos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limitar el conjunto de resultados a los elementos excepto a aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limita los resultados a entradas con un valor espec\u00edfico menu_order.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"default":1,"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \"categor\u00eda\", \"entrada\" o \"adjunto\".","type":"string","required":false},"object_id":{"default":0,"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \"categor\u00eda\", \"entrada\" o \"adjunto\".","type":"string","required":false},"object_id":{"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \"categor\u00eda\", \"entrada\" o \"adjunto\".","type":"string","required":false},"object_id":{"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a entradas publicadas antes de  una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limitar el conjunto de resultados a los elementos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limitar el conjunto de resultados a los elementos excepto a aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud predeterminado del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID de una plantilla","type":"string","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar al ID de entrada especificado.","type":"integer","required":false},"area":{"description":"Limitar al \u00e1rea de la parte especificada de la plantilla.","type":"string","required":false},"post_type":{"description":"Tipo de contenido para el que obtener las plantillas.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"default":"","description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"default":"publish","description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"El slug de la plantilla para conseguir una alternativa","type":"string","required":true},"is_custom":{"description":"Indica si es una plantilla personalizada o forma parte de la jerarqu\u00eda de plantillas","type":"boolean","required":false},"template_prefix":{"description":"El prefijo de la plantilla para la plantilla creada. Se usa para extraer el tipo de plantilla principal, p. ej. en `taxonomia-libros` extrae `taxonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID de una plantilla","type":"string","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar al ID de entrada especificado.","type":"integer","required":false},"area":{"description":"Limitar al \u00e1rea de la parte especificada de la plantilla.","type":"string","required":false},"post_type":{"description":"Tipo de contenido para el que obtener las plantillas.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"default":"","description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"default":"publish","description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"El slug de la plantilla para conseguir una alternativa","type":"string","required":true},"is_custom":{"description":"Indica si es una plantilla personalizada o forma parte de la jerarqu\u00eda de plantillas","type":"boolean","required":false},"template_prefix":{"description":"El prefijo de la plantilla para la plantilla creada. Se usa para extraer el tipo de plantilla principal, p. ej. en `taxonomia-libros` extrae `taxonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"El ID de una plantilla","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n de estilos globales.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n de estilos globales.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"El identificador del tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"El identificador del tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID de la configuraci\u00f3n de estilos globales.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Estilos globales.","type":["object"],"required":false},"settings":{"description":"Ajustes globales.","type":["object"],"required":false},"title":{"description":"T\u00edtulo de la variaci\u00f3n de estilos globales.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la variaci\u00f3n de estilos globales, tal y como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a entradas publicadas antes de  una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"declaraci\u00f3n font-family en formato theme.json, codificada como cadena.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"declaraci\u00f3n font-family en formato theme.json, codificada como cadena.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"declaraci\u00f3n font-face en formato theme.json, codificada como cadena.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para el font face.","type":"integer","required":true},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para el font face.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/portfolio":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las entradas asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Aseg\u00fara que el conjunto de resultados excluye las entradas asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limita la respuesta a entradas publicadas antes de  una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"portfolio-category":{"description":"Limitar el conjunto de resultados a los elementos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda portfolio-category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si incluir los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"portfolio-category_exclude":{"description":"Limitar el conjunto de resultados a los elementos excepto a aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda portfolio-category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Compara los t\u00e9rminos con los ID de la lista.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID de los t\u00e9rminos.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si incluir los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"portfolio-category":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda portfolio-category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/portfolio"}]}},"\/wp\/v2\/portfolio\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud predeterminado del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"portfolio-category":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda portfolio-category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/portfolio\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping la entrada o no.","type":"string","enum":["open","closed"],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"portfolio-category":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda portfolio-category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/portfolio\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/penci-block":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limita la respuesta a entradas publicadas antes de  una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/penci-block"}]}},"\/wp\/v2\/penci-block\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/penci-block\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido para la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_lmt_disableupdate":{"type":"string","title":"","description":"","default":""},"_lmt_disable":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}]},"\/wp\/v2\/penci-block\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Un identificador alfanum\u00e9rico del tipo de contenido.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Un identificador alfanum\u00e9rico del estado.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limita los resultados a taxonom\u00edas asociadas con un tipo de contenido espec\u00edfico.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Un identificador alfanum\u00e9rico de la taxonom\u00eda.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"parent":{"description":"Limita el resultado a t\u00e9rminos asignados a un superior espec\u00edfico.","type":"integer","required":false},"post":{"description":"Limita el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"parent":{"description":"Identificador del t\u00e9rmino superior.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"parent":{"description":"Identificador del t\u00e9rmino superior.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"post":{"description":"Limita el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"post":{"description":"Limita el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"Las ubicaciones asignadas al men\u00fa.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Si quieres a\u00f1adir autom\u00e1ticamente las p\u00e1ginas de nivel superior a este men\u00fa.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"Las ubicaciones asignadas al men\u00fa.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Si quieres a\u00f1adir autom\u00e1ticamente las p\u00e1ginas de nivel superior a este men\u00fa.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"post":{"description":"Limita el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/portfolio-category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"parent":{"description":"Limita el resultado a t\u00e9rminos asignados a un superior espec\u00edfico.","type":"integer","required":false},"post":{"description":"Limita el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"parent":{"description":"Identificador del t\u00e9rmino superior.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/portfolio-category"}]}},"\/wp\/v2\/portfolio-category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del t\u00e9rmino \u00fanico de este tipo.","type":"string","required":false},"parent":{"description":"Identificador del t\u00e9rmino superior.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordenar la colecci\u00f3n por el atributo del usuario.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limitar el resultado a usuarios con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limita el resultado a usuarios que se ajusten al menos a un perfil espec\u00edfico facilitado. Acepta listas en csv o un solo perfil.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limita el conjunto de resultados a usuarios que coincidan, al menos, con una capacidad espec\u00edfica proporcionada. Acepta listas en CSV o una \u00fanica capacidad.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limitar el resultado a usuarios considerados autores.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limitar el resultado a usuarios que han publicado entradas.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","portfolio":"portfolio","penci-block":"penci-block"}},"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nombre de inicio de sesi\u00f3n del usuario.","type":"string","required":true},"name":{"description":"Muestra el nombre del usuario.","type":"string","required":false},"first_name":{"description":"Nombre del usuario.","type":"string","required":false},"last_name":{"description":"Apellidos del usuario.","type":"string","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico del usuario.","type":"string","format":"email","required":true},"url":{"description":"Enlace del usuario.","type":"string","format":"uri","required":false},"description":{"description":"Descripci\u00f3n del usuario.","type":"string","required":false},"locale":{"description":"Configuraci\u00f3n local del usuario.","type":"string","enum":["","en_US","de_DE","en_GB","es_MX"],"required":false},"nickname":{"description":"Alias del usuario.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del usuario.","type":"string","required":false},"roles":{"description":"Perfiles asignados al usuario.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Contrase\u00f1a del usuario (no incluida).","type":"string","required":true},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La fecha y hora en que se actualizaron las preferencias.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"penci_avatar":{"description":"The users simple local avatar","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del usuario.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del usuario.","type":"integer","required":false},"username":{"description":"Nombre de inicio de sesi\u00f3n del usuario.","type":"string","required":false},"name":{"description":"Muestra el nombre del usuario.","type":"string","required":false},"first_name":{"description":"Nombre del usuario.","type":"string","required":false},"last_name":{"description":"Apellidos del usuario.","type":"string","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico del usuario.","type":"string","format":"email","required":false},"url":{"description":"Enlace del usuario.","type":"string","format":"uri","required":false},"description":{"description":"Descripci\u00f3n del usuario.","type":"string","required":false},"locale":{"description":"Configuraci\u00f3n local del usuario.","type":"string","enum":["","en_US","de_DE","en_GB","es_MX"],"required":false},"nickname":{"description":"Alias del usuario.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del usuario.","type":"string","required":false},"roles":{"description":"Perfiles asignados al usuario.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Contrase\u00f1a del usuario (no incluida).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La fecha y hora en que se actualizaron las preferencias.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"penci_avatar":{"description":"The users simple local avatar","type":"object","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del usuario.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que los usuarios no son compatibles con el env\u00edo a la papelera.","required":false},"reassign":{"type":"integer","description":"Reasignando las entradas y los enlaces del usuario borrado a la ID de ese usuario.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nombre de inicio de sesi\u00f3n del usuario.","type":"string","required":false},"name":{"description":"Muestra el nombre del usuario.","type":"string","required":false},"first_name":{"description":"Nombre del usuario.","type":"string","required":false},"last_name":{"description":"Apellidos del usuario.","type":"string","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico del usuario.","type":"string","format":"email","required":false},"url":{"description":"Enlace del usuario.","type":"string","format":"uri","required":false},"description":{"description":"Descripci\u00f3n del usuario.","type":"string","required":false},"locale":{"description":"Configuraci\u00f3n local del usuario.","type":"string","enum":["","en_US","de_DE","en_GB","es_MX"],"required":false},"nickname":{"description":"Alias del usuario.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del usuario.","type":"string","required":false},"roles":{"description":"Perfiles asignados al usuario.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Contrase\u00f1a del usuario (no incluida).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La fecha y hora en que se actualizaron las preferencias.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false},"penci_avatar":{"description":"The users simple local avatar","type":"object","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Se requiere que sea true, ya que los usuarios no son compatibles con el env\u00edo a la papelera.","required":false},"reassign":{"type":"integer","description":"Reasignando las entradas y los enlaces del usuario borrado a la ID de ese usuario.","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Un UUID proporcionado por la aplicaci\u00f3n para identificarla de forma \u00fanica. Se recomienda usar un UUID v5 con la URL o el espacio de nombres DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"El nombre de la contrase\u00f1a de la aplicaci\u00f3n.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Un UUID proporcionado por la aplicaci\u00f3n para identificarla de forma \u00fanica. Se recomienda usar un UUID v5 con la URL o el espacio de nombres DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"El nombre de la contrase\u00f1a de la aplicaci\u00f3n.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limita la respuesta a comentarios publicados despu\u00e9s de una fecha dada compatible con ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a comentarios asignados a identificadores de usuario espec\u00edficos. Requier autorizaci\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Asegurarse de que el conjunto de resultados excluye los comentarios asignados a IDs de usuario espec\u00edficos. Requiere autorizaci\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limitar el conjunto de resultados a aquellos con un correo electr\u00f3nico de autor espec\u00edfico. Requiere autorizaci\u00f3n.","format":"email","type":"string","required":false},"before":{"description":"Limita la respuesta a comentarios publicados antes de una fecha dada compatible con ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del comentario.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limita el resultado a comentarios con ID superiores espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Aseg\u00farate de que el conjunto de resultados excluya los IDs superiores espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limita el resultado a comentarios asignados a ID de entrada espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limitar el conjunto de resultados a los comentarios asignados a un estado espec\u00edfico. Requiere autorizaci\u00f3n.","type":"string","required":false},"type":{"default":"comment","description":"Limitar el conjunto de resultados a los comentarios asignados a un tipo espec\u00edfico. Requiere autorizaci\u00f3n.","type":"string","required":false},"password":{"description":"La contrase\u00f1a para la entrada si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"El ID del objeto del usuario, si el autor era un usuario.","type":"integer","required":false},"author_email":{"description":"Direcci\u00f3n de correo electr\u00f3nico del autor del comentario.","type":"string","format":"email","required":false},"author_ip":{"description":"Direcci\u00f3n IP del autor del comentario.","type":"string","format":"ip","required":false},"author_name":{"description":"Muestra el nombre del autor del comentario.","type":"string","required":false},"author_url":{"description":"URL del autor del comentario.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usuario para el autor del comentario.","type":"string","required":false},"content":{"description":"El contenido para el comentario.","type":"object","properties":{"raw":{"description":"Contenido para el comentario, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para el comentario, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La fecha en la que se public\u00f3 el comentario, en la zona horaria del sitio.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que el comentario fue publicado, como GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"El ID del superior del comentario.","type":"integer","required":false},"post":{"default":0,"description":"El ID del objeto asociado a la publicaci\u00f3n.","type":"integer","required":false},"status":{"description":"Estado del comentario.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Estado de resoluci\u00f3n de la nota","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para el comentario.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a de la entrada superior del comentario (si la entrada est\u00e1 protegida por contrase\u00f1a).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para el comentario.","type":"integer","required":false},"author":{"description":"El ID del objeto del usuario, si el autor era un usuario.","type":"integer","required":false},"author_email":{"description":"Direcci\u00f3n de correo electr\u00f3nico del autor del comentario.","type":"string","format":"email","required":false},"author_ip":{"description":"Direcci\u00f3n IP del autor del comentario.","type":"string","format":"ip","required":false},"author_name":{"description":"Muestra el nombre del autor del comentario.","type":"string","required":false},"author_url":{"description":"URL del autor del comentario.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usuario para el autor del comentario.","type":"string","required":false},"content":{"description":"El contenido para el comentario.","type":"object","properties":{"raw":{"description":"Contenido para el comentario, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para el comentario, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La fecha en la que se public\u00f3 el comentario, en la zona horaria del sitio.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que el comentario fue publicado, como GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"El ID del superior del comentario.","type":"integer","required":false},"post":{"description":"El ID del objeto asociado a la publicaci\u00f3n.","type":"integer","required":false},"status":{"description":"Estado del comentario.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Estado de resoluci\u00f3n de la nota","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para el comentario.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"password":{"description":"La contrase\u00f1a de la entrada superior del comentario (si la entrada est\u00e1 protegida por contrase\u00f1a).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"type":{"default":"post","description":"Limitar resultados a elementos de un tipo de objeto.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limitar resultados a elementos de uno o m\u00e1s subtipos de objetos.","type":"array","items":{"enum":["post","page","portfolio","penci-block","category","post_tag","portfolio-category","any"],"type":"string"},"required":false},"exclude":{"description":"Asegurarse de que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nombre \u00fanico registrado para el bloque.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atributos para el bloque.","type":"object","default":[],"required":false},"post_id":{"description":"ID del contexto de la entrada.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espacio de nombres del bloque.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espacio de nombres del bloque.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nombre del bloque.","type":"string","required":false},"namespace":{"description":"Espacio de nombres del bloque.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"themeisle_sdk_promotions":{"title":"","description":"","type":"string","required":false},"themeisle_sdk_promotions_otter_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_optimole_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_rop_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_neve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_redirection_cf7_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_hyve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_wp_full_pay_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_masteriyo_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_easy_mcp_installed":{"title":"","description":"","type":"boolean","required":false},"title":{"title":"T\u00edtulo","description":"T\u00edtulo del sitio.","type":"string","required":false},"description":{"title":"Descripci\u00f3n corta","description":"Descripci\u00f3n corta del sitio.","type":"string","required":false},"timezone":{"title":"","description":"Una ciudad en la misma zona horaria que t\u00fa.","type":"string","required":false},"date_format":{"title":"","description":"Formato fecha para todas las cadenas de fecha.","type":"string","required":false},"time_format":{"title":"","description":"Formato de tiempo para todas las cadenas de tiempo.","type":"string","required":false},"start_of_week":{"title":"","description":"El n\u00famero de d\u00eda en el que la semana debe comenzar.","type":"integer","required":false},"language":{"title":"","description":"C\u00f3digo del local de WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Convierte emoticonos como :-) y :-P en gr\u00e1ficos en la pantalla.","type":"boolean","required":false},"default_category":{"title":"","description":"Categoria de entrada por defecto","type":"integer","required":false},"default_post_format":{"title":"","description":"Formato de la entrada por defecto.","type":"string","required":false},"posts_per_page":{"title":"M\u00e1ximo de entradas por p\u00e1gina","description":"Las p\u00e1ginas de blog muestran como m\u00e1ximo.","type":"integer","required":false},"show_on_front":{"title":"Mostrar en la portada","description":"Qu\u00e9 mostrar en la p\u00e1gina de inicio","type":"string","required":false},"page_on_front":{"title":"P\u00e1gina en la portada","description":"El ID de la p\u00e1gina que debe mostrarse en la p\u00e1gina de inicio","type":"integer","required":false},"page_for_posts":{"title":"","description":"El ID de la p\u00e1gina que debe mostrar las \u00faltimas entradas","type":"integer","required":false},"default_ping_status":{"title":"","description":"Permite notificaciones de enlaces desde otros sitios (pingbacks y trackbacks) en los nuevos art\u00edculos.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Permitir comentarios en las entradas nuevas","description":"Permitir a la gente publicar comentarios en las entradas nuevas.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logotipo","description":"Logotipo del sitio","type":"integer","required":false},"site_icon":{"title":"\u00cdcono","description":"\u00cdcono del sitio.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limitar el conjunto de resultados a los temas asignados a uno o m\u00e1s estados. ","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"La hoja de estilos del tema. Esto identifica el tema de forma \u00fanica.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"status":{"description":"Limita los resultados a plugins con el estado dado.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug del plugin en el directorio WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Estado de activaci\u00f3n del plugin.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Estado de activaci\u00f3n del plugin.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El ID de una barra lateral registrada","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgets anidados.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El ID del tipo de widget.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"El ID del tipo de widget.","type":"string","required":true},"instance":{"description":"Ajustes de la instancia actual del widget.","type":"object","required":false},"form_data":{"description":"Datos serializados de formulario de widget para cifrar en los ajustes de la instancia.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"El ID del tipo de widget.","type":"string","required":true},"instance":{"description":"Ajustes de la instancia actual del widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"La barra lateral a la que devolver el widget.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para el widget.","type":"string","required":false},"id_base":{"description":"El tipo de widget. Corresponde al ID en la variable widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"La barra lateral a la que pertenece el widget.","type":"string","required":true},"instance":{"description":"Ajustes de la instancia del widget, si es compatible.","type":"object","properties":{"encoded":{"description":"Representaci\u00f3n base64 cifrada de los ajustes de la instancia.","type":"string","context":["edit"]},"hash":{"description":"Hash criptogr\u00e1fico de los ajustes de la instancia.","type":"string","context":["edit"]},"raw":{"description":"Ajustes de instancia sin cifrar, si es compatible.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Datos de formulario con la URL sin cifrar del formulario de administraci\u00f3n del widget. Se usa para actualizar un widget que no tenga compatibilidad con instancias. Solo escritura.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico para el widget.","type":"string","required":false},"id_base":{"description":"El tipo de widget. Corresponde al ID en la variable widget-types.","type":"string","required":false},"sidebar":{"description":"La barra lateral a la que pertenece el widget.","type":"string","required":false},"instance":{"description":"Ajustes de la instancia del widget, si es compatible.","type":"object","properties":{"encoded":{"description":"Representaci\u00f3n base64 cifrada de los ajustes de la instancia.","type":"string","context":["edit"]},"hash":{"description":"Hash criptogr\u00e1fico de los ajustes de la instancia.","type":"string","context":["edit"]},"raw":{"description":"Ajustes de instancia sin cifrar, si es compatible.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Datos de formulario con la URL sin cifrar del formulario de administraci\u00f3n del widget. Se usa para actualizar un widget que no tenga compatibilidad con instancias. Solo escritura.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Si forzar la eliminaci\u00f3n del widget o moverlo a la barra lateral inactiva.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limitar el resultado a bloques que coincidan con el t\u00e9rmino de b\u00fasqueda.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","minLength":1,"required":false},"category":{"description":"Limitar los resultados a los que coincidan con un ID de categor\u00eda.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limita los resultados a aquellos que coincidan con un ID de palabra clave.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limita los resultados a los que coinciden con un patr\u00f3n (slug).","type":"array","required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL a procesar.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Un identificador alfanum\u00e9rico de la ubicaci\u00f3n del men\u00fa.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identificador \u00fanico de la categor\u00eda de habilidad.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identificador \u00fanico de la habilidad.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Par\u00e1metros de entrada para la ejecuci\u00f3n de la habilidad.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limita los resultados a habilidades en la categor\u00eda de habilidad espec\u00edfica.","type":"string","required":false},"namespace":{"description":"Limita los resultados a las habilidades de un espacio de nombres concreto.","type":"string","required":false},"meta":{"description":"Limita los resultados a las habilidades que coincidan con todos los campos meta indicados.","type":"object","properties":{"annotations":{"description":"Limita los resultados a las habilidades que coincidan con las anotaciones de comportamiento indicadas.","type":"object","properties":{"readonly":{"description":"Indica si la capacidad no modifica su entorno.","type":["boolean","null"]},"destructive":{"description":"Indica si la capacidad puede realizar actualizaciones destructivas en su entorno.","type":["boolean","null"]},"idempotent":{"description":"Indica si las llamadas repetidas con los mismos argumentos no tienen ning\u00fan efecto adicional.","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Identificador \u00fanico de la habilidad.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"collection":{"description":"Limitar los resultados a los iconos que pertenecen al slug de colecci\u00f3n indicado.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"Limitar los resultados a los iconos que pertenecen al slug de colecci\u00f3n indicado.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nombre del \u00edcono.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar resultados a aquellos que coinciden con una cadena.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug de la colecci\u00f3n de \u00edconos.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Tipo de entidad.","type":"string","required":true},"name":{"description":"Nombre de la entidad.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/www.emag.com\/blog\/es\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":0,"site_icon":0,"site_icon_url":"https:\/\/www.emag.com\/blog\/es\/wp-content\/uploads\/sites\/3\/2025\/02\/emag-logo-header3.png","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}]}}
